WinARM
<><B>Version 20050427</B></P>
<>WinARM is collection of tools to develop Applications for ARM-Controllers in C and C++ on MS-Windows platforms.
Installation
<>Unpack the archive and extend the system search-path (%PATH%) by C:\WinARM\bin;C:\WinARM\utils\bin; </P>
ComponentsGNU-C/C++-Compiler (cross compiler/linker/assembler arm-elf-*) Version 4.0.0 incl. stdlib3. Compiled from the FSF-Sources using a patch from gnuarm.org. The configuration supports ARM-Mode, Thumb-Mode and Mixed(ARM/Thumb)-Mode, little/big-endian and floating point-emulation (all targets which are also supported by gnuarm)
GNU-Binutils Version Version 2.15.94 (from mingw)
newlib Version 1.13.0 (reentrant-build)
newlib-lpc Rel.4 (reentrant functions to fill newlib-stubs for Philips LPCs)
GNU-<B>Utils</B> do support the compiler/linker (make, sh etc. all Win32-native)
ARM header-files (register-defintions) from gnuarm.org
<B>Example applications</B> with full source-code, makefiles, linker-scripts and startup-code (partly tested with Philips LPC2106 ARM7TDMI)
Programmers Notepad Editor Version 2.0.5.48
The lpc21isp in-system-programming-software for Philips LPC 210x and the Analog Devices ADUC 70xx family by Martin Maurer
Bray Terminal
Insight-GDB 5.2.1 (old) - Win32-Native (devkit.tk)
Setup-Exe of Macraigors OCDRemote HintsProgrammers Notepad can be used as Editor. Some items in the tools-menue have been added for WinARM. First steps: start Programmer-Notepad (pn/pn.exe) and load a project file from the examples.
The makefiles supplied with the examples can be used as templates for own projects.
Some documentation is included - see the doc/ subdirectory
For JTAG-debugging e.g. with a "Wiggler": install ocdremote from subdirectory utils/debugger/macraigor. Start ocdremote and start insight 5.2.1 (utils/debugger/insight/bin/arm-elf-gdb). The supplied version of Insight-gdb is rather old but the only one I've found that works without cygwin-DLLs. More information on the FreeRTOS and Macraigor Web-Pages.
The Bray-Terminal (utils/bin/terminal.exe) can be used for I/O via RS232. RemarksMan and info-pages are included just because there have been created during the build-process. WinARM does not include any software to read these files. See the directory /doc for some documentation in pdf and html-format.
Check out Dev-C++ which offers much more freatures than Programmers Notepad but and can be configured to work with WinARM.
<><B>lease send bug-reports and feedback. Martin Thomas (eversmith@heizung-thomas.de)</B></P>
