AVRSTUDIO 4.18 New Features
发表于 2009-11-20 21:41:41 | 显示全部楼层 | 阅读模式
<pre>Welcome to AVR Studio 4.18 Release Candidate 3 (10/2009)
The following (6) new parts have been added to AVR Studio since 4.17:
- ATmega64HVE, ATtiny461A, ATtiny20, ATtiny40 (Simulator support only), ATmega169PA, ATmega649P
New Features
QT600 support in programming dialog in AVR Studio
AVR Dragon support for all AVR 8-bit devices including XMEGA. Programming and debugging within AVR Studio and command line software support for ELF production file format.
Simulator 2 models for: ATxmega32A4, ATxmega16A4, ATxmega32D4, ATxmega16D4, ATtiny10(New revision), ATtiny9, ATtiny5, ATtiny4, ATmega32HVB, ATmega16HVB
ATmega64HVE, ATtiny20, ATtiny2313A, ATtiny4313, ATmega169PA
Added button for starting AVR32 Studio.
Bug Fixes
*Minor fix for un-installing USB driver. Will not completely un-install so that other programs using the Jungo driver will still work.
10397 - Timeout when debugging with AVR ONE! at 6 kHz
10147 - avrone.exe pops up messagebox for FW upgrade, warning is displayed instead.
9805 - TWI part descriptions broken for ATxmega parts in latest AVR Studio release
10387 - Xmega Erase Boot Section not woking for ISPmkII
9847 - AVRDragon.exe -C:USB S/N parameter missing
8111 - Programming dialog does not set emulator mode X-Jtag for JTAGICE mkII/AVR Dragon
8251 - AVR Studio refuses to accept AVR Dragons with slave major version 3
9993 - xmega osccal calibration in avrone.exe
10234 - Incorrect information of daisy chain setup in help file
10498 - AVR ONE! node missing in ATtiny2313A XML
10505 - SPH register missing from tiny4313 part description file
10518 - DWbasePC is wrong in m649.xml
6828 -  Bugs in ATtiny48 part description
9573 -  Fuse view in does not show the RSTDSBL bit for xmega devices
10713 - RSTDISBL fuse description missing in XMEGA xml files
9961 - Simulator2: Single-stepping stops on skipped instruction after SBIC/SBIS instructions
10703 - Simulator 2: Single-stepping problem on xmega
10722 - Moving XMEGA breakpoints does not work, JTAGICE mkII, AVR ONE!
Note
Windows 95 is no longer supported by AVR Studio. The most recent version that supported Windows 95 was AVR Studio 4.12 SP3.
Windows 98 is no longer supported by AVR Studio. The most recent version that supported Windows 98 was AVR Studio 4.16 SP1.
</pre>
二年级
发表于 2009-11-27 17:13:43 | 显示全部楼层
<p></p><p>AVR Dragon support for all AVR 8-bit devices including XMEGA. </p><p>Dragon超值了。</p>
发表于 2009-11-27 17:30:01 | 显示全部楼层
本站的mkII-CN在去年就支持XMEGA了,更超值
